RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
interesting...
Old 04-07-2008, 08:16 PM
richib86's Avatar
Default interesting...
<ul><li><a href="http://www.rs246.com/index.php?name=PNphpBB2&amp;file=viewtopic&amp;t=6 9469">http://www.rs246.com/index.php?name=PNphpBB2&amp;file=viewtopic&amp;t=6 9469</a</li></ul>
Old 04-08-2008, 06:20 AM
RI A6's Avatar
Default Quite ... if you go with this, you'll want to go to a lower viscosity oil
The engine is designed for these high temperatures. In order to compensate for increased cooling, you'll need to adjust the oil so that the viscosity at operating temperature is the same as it was stock. This will ensure the proper oil flow, bearing hydrodynamic lift, and internal drag reduction. Otherwise, internal wear and fuel consumption can increase.
In Europe they already run 5W30 weight oil. With enough cooling, the operating weight could potentially be reduced to a 5W-20 racing oil.
Old 04-08-2008, 08:38 AM
AudiWorld Expert
Reggie's Avatar
Was there a picture of this? Could not find one
Old 04-08-2008, 09:50 AM
richib86's Avatar
Ya, U need to register on the forum to view pictures
Thlampman
Q7 MK 1 Discussion
10-27-2016 03:13 AM
zamicus
08-19-2004 12:48 PM
TS90
13
01-14-2003 12:54 PM
YS4
08-15-2002 08:23 AM
RobbyTT
9
04-01-2001 07:46 PM
Quick Reply: interesting...
