RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Is my car permanently stuck in "S" mode....
Old 12-29-2006, 06:02 PM
Vijay's Avatar
Default Is my car permanently stuck in "S" mode....
when I hit the S button, light goes on, but I don't hear or feel anything different. Mind you, I'm not using full throttle or going above 6k rpm at this point. When parked, with the car off, both exhaust valves are open. Is this normal or am I stuck in S mode and therefore not feeling/hearing any change when I hit the button.
From my previous post....TPMS seems to be be a real problem. Malfunction light staying on. Tire pressures at 38 psi all around. The system tries to reset, states that it is storing new tire pressures when I go through the protocol, but warning light never goes off.
Old 12-29-2006, 06:25 PM
Senior Member
McGyver's Avatar
Default Start car, wait until rpms drop below 1k, then hit the "s" button
you'll notice the deep growl. Drive off an enjoy, :-)
Old 12-29-2006, 06:40 PM
RSIV's Avatar
Default Re: "Is this normal or am I stuck in S mode..." normal?-yes...and S-mode only changes the car ;)
Any chance you are picking up the other tires and they are low?
Are you going by the TSS pdf's at the link I posted?<ul><li><a href="https://forums.audiworld.com/rs4b7/threads/2798.phtml#33258">Did anyone guess right? How much did they check/go over with you at delivery?</a></li></ul>
Old 12-29-2006, 08:39 PM
New Member
abwc's Avatar
Default If you perchance to tail another RS4, you will notice
that the sport flap opens at idle, then closes on throttle from a Stop when Sport mode is off.
Presumably, this is to prevent moisture buildup behind the butterfly at idle when one exit is blocked.
That explains the visual.
The audible was explained by McGyver; sport mode cannot be heard at cetain rpm, notibly the off-idle rpm just after cold start.
Try this out: stand at the trunk when idling with sport mode on; it's deafening !
Old 12-29-2006, 11:41 PM
New Member
Bob W. - undead's Avatar
Default with the car stopped and idling, there should be an audible difference....
...when switching from S to non-S. At engine speeds above idle, it's not really noticeable.
Old 12-30-2006, 04:50 AM
Vijay's Avatar
Ahhhh.......so many little things to learn!
Old 01-02-2007, 02:25 PM
New Member
AUDIFAN008's Avatar
just reset the TPMS when all 4 tires at correct psi.
johnsfer
Audi A3 / S3 / RS 3 MKII
12-21-2017 08:22 AM
am_ver
06-12-2010 01:58 AM
raaizin
04-20-2009 06:28 AM
epfrisco
Audi allroad
9
02-14-2008 01:34 PM
Quick Reply: Is my car permanently stuck in "S" mode....
