New Winter Shoes just in time for another dump!
<center><img src="http://www.ecocharge.com/jsy/rs4_winterB.jpg"></center><p>
Here's my new Hartmann RS6 replika snow wheels. These are identical to the OEM Audi winter wheel that was offered for the RS6. Size: 18 x 7.5 et20, clad with Dunlop WinterSport M3's. I know they are not as sexy as the stocker 19's, but this is a far better snow driving setup than using a 19 x 9. The wheel is recessed 5mm, so there is considerably less chance for muck making contact with the paint. Not a bad price at $270 each. Bring on the snow!
it looks tight from the outside, but the wheel opens a bit on the inside, prolly 3 to 4mm...
2mm is said to be the minimum clearance for wheel to caliper. I've got that and a bit more. It's tight but works well.
where is that? some private road in ND/SD/WY? what size tires? would 235/40/18 fit like this on ebay
<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=003&sspagename=S TRK%3AMESE%3AIT&viewitem=&item=13006176580 0">http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=003&sspagename=S TRK%3AMESE%3
No. 235's would be a bit too bulgy on 7.5" rim.
225/45 x 18 is perfect for a 7.5" rim. This also maintains the correct outside diameter (closest to the 255/35 x 19 summer tires).
If you had an 8" rim you could use 235/45 x 18. The 40 series tire would give you the wrong outside diameter.
