OK I give up. Can anyone tell me the cylinder numbering?
The layout of the block, not the firing order. I just spent an hour searching the forum and eBahn.
that appears to be correct....belt pulley side is at the rear of the engine, yes?
looking in eBahn under 'piston and connecting rod, assembly', 4th diagram from the bottom of the page shows bank I-IV looking something like this:
pulley side-------center of engine----------------
-----------------I - II - III - IV----------------
Not sure what you mean by belt/pulley at rear of engine...
I believe the only belt and pulley is at the front
<img src="http://lh6.google.com/mattb93/ReezoKie05I/AAAAAAAAA3w/term32fpnIk/s800/Audi-RS4-2005-022.jpg" />
<img src="http://lh6.google.com/mattb93/ReezoKie02I/AAAAAAAAA3Y/vJw7TZXKzqc/s800/RSFSIengine.jpg" />
i'm not sure what it means either, but that's what is written in eBahn/Bentley.
if we're talking about the same 'belt pulley', then the diagram seems to suggest the cylinder numbering is the opposite of the S4, i.e.:
front----V - VI - VII - VIII
center
front----I - II - III - IV
center
This might be better. Note the injector and coil pack locations...
<ul><li><a href="http://www.showyourmedia.com/membersonly/index.php?action=downloadfile&filename=RS4%20B NS%20Engine%20Component%20locations.pdf&direct ory=mattb93&">PDF from Bentley</a></li></ul>
Pat
02-05-2008 11:01 AM
afourbfive
12-06-2006 05:18 PM
Shep 1.8T
VAG-COM Discussion
07-06-2005 10:23 PM
