Ordered VAG-COM CAN, could someone please recommend a good source for programming options?
I found one of Sparky's Duff Beer writeups (thanks Sparkhill), but is there a place with other options available? So far, here's my VAG-COM target list:
1. Disable Automatic Locking when car is in motion
2. Disable Automatic re-locking after button press if no doors are opened within 60 seconds
3. Enable unlock ALL doors with one press of key fob
4. Enable windows down with key fob
5. Enable fogs with high beams
6. Disable confirmation beep upon arming
7. Disable seat belt reminder (beeper).
8. Disable amber marker lights (Euro programming)
Looking for programming help for the above, plus any other options. Thanks!
As long as I'm not responsible if you screw-up your car...
Address 46 - Central Convenience
Change from 11820 to 10824 (without auto re-lock)
OR
Change from 11820 to 2632 (possibly without auto re-lock)
Here are the details:
-Disable Automatic Locking when car is in motion
subtract 32
I am not sure about this one, but try to subtract 8192
subtract 4
add 64 (must also use Channel 62)
subtract 1024
Address 09 - Central Electronics
Enable fogs with high beams and Disable amber marker lights (Euro programming)
change from 1023 to 1021
Address 17 - Instruments
change from 23261 to 23259
OR
subtract 32
subtract 4
subtract 1024
Thanks fellas for the help, much appreciated. Ordered...
Ordered from the good folks at Ross-Tech yesterday 2:00 p.m., the HEX-USB+CAN package arrived 9:00 a.m. this morning.
Let the programming begin!
Got everything programmed except disable Automatic Relock after 60 seconds
I'll post over in the VAG-COM section to see if anyone's figured it out.
The windows down/up with key fob is nice if you forget to close windows once you're out of the car. Just hold the lock button down and all windows close! Thanks again for the help.
And you even did the math for me....
Thanks Bro. I one-upped you though and disabled the seat belt reminder completely, not even an initial beep! I have no intention of driving without seatbelts, but the beeper chime gets real annoying when there's no intention of starting the car and moving.
I owe you a few Duffs
Inside...
Change from 0023261 to 00232<b>0</b>1
Format is 00xxx?1
? = <b>0</b> = "No seatbelt warning"
Format is 00xxx?1
penguin101b
VAG-COM Discussion
02-05-2006 06:09 PM
polishadonis
10-12-2005 04:01 AM
