purchase RS4 issues
I am ready to pull the trigger on a used '07 RS4 69k miles. I have had an Audi S4 2001 as a new car, never any problems. Now I am considering a 9 year old car. I would appreciate your collective candor and advice. Would love to be back in the "Audi 4 club:"
1. what problems are common for these cars? 2. Does the RS4 engine have the same timing chain pully and tensioner problems as reported for the S4? |
Good luck with the sale.
I wouldn't call the DRC a problem area after the recall has been done. But it is expensive to fix. Control arms tend to wear out pretty quick. Brakes last a long time with the right pads and gentle use, but when they go, they're expensive too. Carbon cleaning doesn't need to be done regularly, but if you want the maximum power that you paid for, it should be done every 15K miles or so. Most guys find these cars very reliable. The timing chain and tensioner on the RS4 motor is pretty much bullet-proof, as is the entire motor. |
Thank you or the input. Apparently missed the car as it sold right away. Dealer salesman said he was working on it for me and then not...
69,000 mile red RS4. Would have been nice... |
Originally Posted by ELEVENS
(Post 24792037)
I wouldn't call the DRC a problem area after the recall has been done. But it is expensive to fix. Control arms tend to wear out pretty quick. Brakes last a long time with the right pads and gentle use, but when they go, they're expensive too. Carbon cleaning doesn't need to be done regularly, but if you want the maximum power that you paid for, it should be done every 15K miles or so. Most guys find these cars very reliable. The timing chain and tensioner on the RS4 motor is pretty much bullet-proof, as is the entire motor. 1. Front pads and rotors - about $2K 2. Front control arms - about $1500 - Went with 034 Motorsports setup 3. Spark plugs at 35K - $400 No issues with the DRC system (previous owner had recall performed). No obvious power lost without carbon cleaning. +1 on the timing chain and tensioner You won"t regret owning a B7 RS4! |
