Reinforced brake lines installed.
I have not had a chance to test modulation yet.
Front line passing through stock strain relief bracket.
<img src="http://www.mnaudi.com/mymnaudi/images/296/DSCN1551.jpg">
Closeup of hose end at front caliper.
<img src="http://www.mnaudi.com/mymnaudi/images/296/DSCN1554.jpg">
The other end of the front hose.
<img src="http://www.mnaudi.com/mymnaudi/images/296/DSCN1552.jpg">
Rear brake line.
<img src="http://www.mnaudi.com/mymnaudi/images/296/DSCN1559.jpg">
Banjo fitting at the rear caliper. The yellow goop at the end of the black bit covering the hose is sealant to prevent crap from getting into the joint between the fitting and the hose. The hose itself is covered in clear vinyl to prevent dirt from getting between the braid and the liner.
<img src="http://www.mnaudi.com/mymnaudi/images/296/DSCN1561.jpg">
The other end of the rear brake line.
<img src="http://www.mnaudi.com/mymnaudi/images/296/DSCN1555.jpg">
Rear brake line.
