RS4 Bluetooth problems with LG VX 9900 EnV....
When I first get in the car it's sync'ing up just fine, but will drop out and ding again about 10 seconds after syncing. Have removed/re-installed both on phone and nav setup. If I fool with it long enough to connect/reconnect, it will sometimes work just fine. Signal is strong with 3-4 bars (when connected). I've searched the forum, but can't find much info.
Any help would be appreciated.
Re: RS4 Bluetooth problems with LG VX 9900 EnV....
Blackberry 7130e here. Maybe it's just my car, but heat does that to mine. Fine in the winter and when it's cold, but anything (very roughly) 50 degrees or above and it's sync/unsync's constantly. Like you, I've tried everything multiple times. Isolated the problem to the car's temperature.
Re: FWIW, the iPhone did the same thing until the software was updated
How do I update the software???? Software on phone or on the nav unit?
I've left it plugged into the charger also........no difference.
Craig
Craig
SteveLRS4
RS4 (B7 Platform) Discussion
9
03-29-2007 06:33 AM
