RS4 EPC light always on no faults
My 2007 RS4 had the epc light come on after I replaced the clutch and brake pedal switches for the cruise control. The car was not on but I didn't disconnect the battery. After replacing the switches the cruise control woks fine but the epc light came on with no other faults and no performance loss. I tried to disconnect the battery overnight but it didn't reset. My prochecker does not read any faults and cannot reset the epc.
How do I reset the epc light?
Dumisa Mashele (06-03-2020)
You need a VAG-COM tool from Ross-Tech. It will tell you what's wrong and also reset the light. Of course if the fault is not corrected, the light will come back on again. Good luck, let us know what you find.
I have a VAG V-checker v202 but hate the interface....should have got the Ross tech. It doesn't seem to clear the faults ...yet it cannot detect any faults either. When you check for fault codes do you have to do each component....or does it look for any, because I do have then pre cats gutted which has given me a fault code in the past but doesn't show up on the checker right now.
If you've got the EPC light, there is a error code set. It sounds like your code checker simply can't see it. Which makes me think it misses other important areas as well. Better ebay it and get the real deal.
I think you can do either but I just do them all at once. It takes a few minutes, especially checking for hardware that's not installed, but it's thorough that's for sure.
I now recall that I did start the engine with the light under the dash drivers side disconnected. I've since connected the light and have started car maybe 7-8 times I will cycle it today to see if it goes away. Thanks for the reply.
daredevil1
07-14-2013 05:33 PM
