RS4: Here's the solution, now guess the problem
Looks like you fellers need a hint. According to the forums, this has happened to at least 4 or 5 RS4 owners. Not exactly on the required "maintenance list", but it's definitely something to be aware of, and usually avoidable. The part lists for around $250, I paid $180 through genuineaudiparts.com (San Diego) and it showed up 3 days after ordering w/ 2-day shipping, even though I'm on the other side of The Land. Stealer gets ~ $500 to put it on, making it a $800 repair if you go that route.
It involves engine oil leaking from under the passenger front side. It took 1/2 day to replace the hose, since the bumper cover had to be removed and we all know how much fun THAT is, a.k.a. "service mode" lol. I had to cut the hoses's big nut off with a Dremmel cut-off wheel to avoid wrecking other equipment with gorilla tactics. It was seized up pretty bad. Cmon, we got some very knowledgeable RS4 dudes frequenting this place. |
https://cimg3.ibsrv.net/gimg/www.aud...9d18ead6e0.jpg
Is this the same hose - the one where they would rub if one did not put the rubber grommet in the right place? |
1 Attachment(s)
Yup! Those oil cooler hoses have been a problem on the RS4 way back to the original B5 RS4 platform. The lines appear well built and robust, but if you cut one in half it becomes obvious just how thin-walled they are. If that spacer isn't placed just so, it could lead to problems. Historically they fail at the metal ends from corrosion. That's what happened to mine. Judging by the number of reported failures from B5 RS4 owners, we B7 RS4 owners can expect increased failures as our cars age. My leak was minimal but catastrophic failures are not uncommon.
There are a couple of after-market alternatives, but repairs are not cheap with these cars. Plan a day for the repair as the front bumper has to come off and quite possibly the oil cooler will have to be removed to allow more available options to avoid damage to our $1000 oil cooler during the repair. It wouldn't hurt to change both lines while your at it, but I did just the "short" one as the other one had zero corrosion. To slow future corrosion, I coated the metal parts with a liberal coating of grease. It seems the lower cooler line happens to be located in a drip path and is subject to a lot of moisture. Keep a close eye on your oil cooler lines! |
Great information thanks
Is there anyway to monitor this or at least eyeball the line without pulling the entire bumper?
Originally Posted by sandros1
(Post 24650856)
Yeah a real problem on the RS4, I'm after this kit from JHM
https://jhmotorsports.com/shop/catal...=21_56_310_313 |
