RS4 rim size?
Yes. Offset range that will work is 32 to roughly 24mm for a 19x9.5" wheel. The wheel still has to have a spoke design that will clear the brakes, however, and this is independent of offset. If you need to use a spacer to get the wheel to clear the brakes, the offset decreases by the exact thickness of the spacer i.e. A 10mm spacer used on the stock wheel with a 29mm offset is like having a wheel with a 19mm offset.
louiestt
11-11-2005 07:47 AM
Jo2
04-07-2004 01:20 PM
LobsTTer !!
03-05-2003 09:36 AM
