RS4 Steering Wheel Vibration
New Member
Has anyone out there noticed around 110km/h indicated that there is a vibration through the steering wheel. And i've tried rebalancing of all wheels , swapped front to back and rebalanced. A new set of tyres has not changed the issue or the speed that it occurs at?? Any help or thoughts would be appreciated. Cheers.
When I picked my car I drove it on the highways for like 900 miles to get home. I did all the way to almost 90 mph or more for hours during the 2 days back and I never noticed anything out of the ordinary. No vibration no shaking.
I am with the other members maybe you have a bent or worn tie rod or control arm. From your different switches of tires and a wheels I think it is probably a suspension issue.
Cheers
Nick
Cheers
Nick
Mine does this at certain speeds, on grooved concrete. It's the dunlops tramlining, or some form of it. Causes the steering wheel to jiggle a little bit - car still tracks straight though. This happened on my M5 with Dunlops too despite multiple wheel rebalancing. Doesn't happen on any other type of road surface.
New Member
Orig it had pirelli p zero's and has done this from brand new. I am now running Dunlop super sport race which also have the same issue a the same speed. Dunlops are heaps grippier though and would recomend them to anyone who drives hard on road or track. I have also had both sets of tyres on the hunter machine and also audi's 4 wheel alignment machine without any change.
Had your problem... but
dealer fixed it. I was having issues with my tire pressure gauge. It wasn't working correctly and giving me misreads on my tire pressure. Anyway, I brought it into the shop and they fixed both problems. I think that you should check the tire pressure and or see if your wheels are balanced and rim isn't bent. One of those is the most likely the problem.
