size # of turn signal bulb?..clearing the headlights
does anyones know what size the turn signal bulb is?...body shop is clearing my headlights and they claim that i bulb is amber...im trying to figure out what to replace it with
anyone ever try these
http://www.stealthauto.com/Store/ProductInfo.aspx?productid=SBCA2
Standard Bayonet Base 12V-21W...
...Audi part # N0177328
I'm pretty sure some folks had difficulty with melting the lense due to over heating as a result of replacing w/ a performance bulb. I thought the issue was with Sylvania's SilverStar Signal Bulb (7507A)...but I could be mistaken.
It's an 1156. I used these:
They are painted silver and blink amber. The bulbs inside mine were clear and blinked white, hence the replacement. I don't know why Audi would put an amber bulb inside an amber cone. Seems odd.<ul><li><a href="http://www.autolights4less.com/plt-xc-1156a.html">http://www.autolights4less.com/plt-xc-1156a.html</a</li></ul>
actually, he told me there IS a white bulb there...so im gonna look into getting the stealth bulb
because i have the blinker lights coded to be off when the lights are on, so it will only be amber when blinking..and i dont need trouble with jersey cops
thanks for the size
will post pics when its done, probably wednesday
thanks for the size
Wattage and Amperage of bulb???....
does anyone know the wattage and amperage..body shop claims that while 1156 is the compatible bulb and will fit, audi bulbs may run on different amperage and does not recommend using an aftermarket bulb
stealth bulb that i ordered is
Bulb Specs: 12.8 Volt/ 2.1 Amp Single Contact Bayonet S-8 Type Bulb
absoluteis
RS4 (B7 Platform) Discussion
11
11-24-2008 05:53 PM
quattromano
19
09-09-2003 03:47 PM
MarkFank
Audi allroad
11-13-2001 03:59 PM
