AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   RS4 (B7 Platform) Discussion (https://www.audiworld.com/forums/rs4-b7-platform-discussion-121/)
-   -   Startup after 2 years standstill? (https://www.audiworld.com/forums/rs4-b7-platform-discussion-121/startup-after-2-years-standstill-2892784/)
CSA 11-30-2015 09:57 AM
Hi Guys
I need to startup the car after 2 years standstill in heated, dry garage. Had the oilcap off and if´t looks good down there. However the cams are dry from oil so I'd like to crank the engine to get oil pressure before starting it. Question is: is there a fuse or plug I could pull that will make it turn over without starting, and without drowning the cylinders i unburned fuel?
Reggie 12-03-2015 12:47 PM
Originally Posted by CSA (Post 24748542)
Hi Guys
I would look at the fuse box - Don't have my car anymore but I am sure you can find one that controls the ecu.
If you can I would put oil into each cylinder through removing the spark plugs. If fact pull the plugs and let the engine rotate so there is no compression.
