Stinky after turning it on and off briefly.
Just moved my car from garage to driveway to wash it. Then turned off the engine. The smell of something -- unburnt gas -- was pretty strong. Wow I never experienced this with my other cars.
No wonder why the gas mileage is so bad on this thing.
This pertains to the 2.0T.....
Of course given that the 4.2L is more than twice the size of our engines, the gas might be more exaggerated I'm guessing. I haven't seen a technical document on the 4.2 FSI yet but probably does something similarly...
<i>Cold Start Dual Injection
Dual injection is a special mode of operation for rapid heating of the catalytic converter.
To do this, a quantity of fuel is injected the intake stroke at approximately 300? before TDC of ignition. The fuel distributes itself homogenously due to the long gap before ignition. The second injection occurs at approximately 60? before TDC of ignition during the compression phase.
The rich mixture that forms around the plug means that timing can be retarded a considerable degree without affecting engine stability.
Dual injection also achieves stoichiometric (14.7:1) optimum air/fuel ratio. With the exhaust valves open, the exhaust temperature increases rapidly bringing the catalytic converter up to operating temperature 662° (350?C) very quickly (30-40 seconds).</i>
One of the reasons Audi ships the car with "special hot" plugs is
because things tend to get fouled if the car is started and then shut off before it gets a chance to warm up. As I've posted before, all my S4s have suffered this to some extent. But it sounds like the RS4 is worse. My plan is to take it for a short drive before washing instead of just backing out of the garage and shutting it off.
Hokie - STI avant
14
08-14-2004 04:19 PM
The Turtle
12v V6 Discussion
12
01-24-2004 08:23 PM
