Vag-com codes
Vag-com codes
Is there a comprehensive list of all the codes that can be set using the Vag-COM tool? I keep seeing the same few:
1) PDC pitch and volume
2) Seat-belt chime disable
3) Power windows up/down from key fob
These aren't all that compelling (i.e., not worth the effort) How about:
1) Disabling the auto-door lock feature when car exceeds a certain speed (annoying)
2) Enabling all doors to be unlocked instead of just the driver's door on first press of key fob (default behavior is also annoying)
Thanks,
Thanks,
Re: Vag-com codes
For both of those you need to log in to block 46 - Central Convenience in Vag-Com and recode that module making the changes to the value below.
Subtract 32 from the number you find in block 46 - Central Convenience.
Subtract 4 from the same number you find in 46 - Central Convenience.
So to do what you're asking, subtract 36 from the number you find in block 46 - Central Convenience.
AudiWorld Expert
I love the auto lock feature - I had to add it to my Audi (was not OEM in 98)
but the one touch total unlock I did add. Since the default is for women so they do not get someone getting into the car with them when they unlock the car
Re: Vag-com codes
Excellent. Thanks for the info. If somebody hasn't already, it would be a great idea to start compiling a complete list. I could start putting one together if there's an interest.
polishadonis
10-12-2005 04:01 AM
blackfnTTruck
12
08-01-2005 09:32 AM
