VF RS4 supercharger
I was at VF last week and took a few pics of the progress of the RS4 supercharger development. My first interest was the fit around the fuel pumps and lines and what needed to be moved. It appears the answer is: nothing is moved. The stock intake is also unchanged, just requiring a custom connection pipe from throttle body to s/c input. The Eaton M90 blows up through a water/air intercooler into the intake manifold. The water reservoir for the intercooler will be hidden away behind the driver side wheel with a cooling radiator up front. The manifold shown is from the S4 and is not the one to be used for the RS, a narrower cleaner looking version has been designed. This leads to the height of this set up, which will require a modified hood by way of a power bulge pressed into a stock Aluminium hood. This is included in the kit too.
I'm told that as you are reading this, the parts will all be ready and the final assembly will be in progress for the first fire-up. At the risk of repeating more things you may already know, it'll set you back $16k for the kit, approx $2k for installation and will be installed and supported directly by VF. It should get you 550hp and the mild boost will not require reducing the stock compression from 12.5:1, also the stock exhaust will be retained. That peak power figure doesn't reveal the huge torque from low down in the rev range from this type of s/c though. Thanks obviously to Nik and Sean for encouraging my interest and picture taking while I was there on another unrelated mission. I liked what I saw. I was interested in fit and tidiness and on both counts it was looking good. Can't wait to go back to see it running, just like the owner of the car no doubt! <img src="http://farm4.static.flickr.com/3106/3130118538_f69c14175a.jpg"> <img src="http://farm4.static.flickr.com/3182/3130108492_cb49cc7179.jpg"> <img src="http://farm4.static.flickr.com/3242/3130118530_e82b5eac00.jpg"> <img src="http://farm4.static.flickr.com/3124/3130118546_305ff39ac4.jpg"> <img src="http://farm4.static.flickr.com/3095/3130118558_7a3c7a9171.jpg"> <img src="http://farm4.static.flickr.com/3232/3130118562_f809163992.jpg"> <img src="http://farm4.static.flickr.com/3084/3130118548_4b9e9207ef.jpg"> |
So the S4 S/C will cost half the price, but is basically the same design? That is one pricey hood.
do they have a dealer network for installs/service outside of socal?
Pricier. :(
The price is a little disheartening, I could see an additional $2k markup...
This will probably take me out of the market for it. Which I'm not real happy about either.
I was told it would be installed at VF in Anaheim, no indication of wider support right now
Well, it is better than The $49,000 for the MTM unit that nobody can install......
Apparently the installer that Hoppen wanted to work on the cars in the U.S. didn't want to touch the system. This was according to a previous post on this forum. I don't know the details.
I'm also wondering if the stock tranny can handle the power or does something else need to be done here too, and if so, what are the options? |
I'm guessing AWE will be able to handle installs, but they are in PA.
Better...yes, but still too much considering the cost of the S4 one and the fact that they don't...
even have to guinea pig their own RS4. I hope that guy gets it for free.
Quick math...nope not worth it
at $20K out the door which is roughly 40% of the value of my car...totally not worth it.
