VMR wheels - what centre bore size?
<center><img src="http://www.velocitymotoring.com/images/v710_img3.jpg"></center><p>Been eyeing this set of rims, and I know the B7 RS4s are 5x112. Looking at offset 33 with 5 or 8 mm spacers, but I have no idea what the centre bore is : 57.1 mm or 72.6 mm?<ul><li><a href="http://www.velocitymotoring.com/links/wheels_v710.htm">http://www.velocitymotoring.com/links/wheels_v710.htm</a</li></ul>
These wheels are 19x8.5" with a 35mm (I believe) offset.....
If you want them to line up like the stock wheels, you need a 22mm offset with 8.5" wheels, which translates to a 13mm spacer. A 15 or 20mm spacer would work best.
72.6mm centerbore seems large. I'm willing to bet it is 57.6. Just measure one of your stock wheels.
They are suppose to be coming out with RS4 fitment soon. Also...
Check these out.<ul><li><a href="http://www.audizine.com/forum/showthread.php?t=260303">http://www.audizine.com/forum/showthread.php?t=260303</a</li></ul>
