'05 S4 avant - will '06 Jetta rims work?
I have an '05 S4 Avant with 18" rims. I'd like to have a set of winter rims with snow tires on them and have been looking for a while.
If found a set of '06 Jetta GLI 17" stock rims.
Can anyone advise me if this will work on my car?
I think that going down a size should be ok, but am curious other than my speed gauge being off slightly what else might be an issue.
Thanks in advance for the time to help me out!
No they wont fit, unless you get a set of hubcentric spacers, to change the center bore size, your center bore is 66.5 and your offset is approx 35 to 40, so by using a 20mm hubcentric spacer to change the center bore size, they will fit snug to your arch.
the jetta has a center bore of 57.1 and off set of around 45 to 54
Thanks much! Was a screaming deal I'd hoped would work.
If anyone has a cheap set of winter rims that'll work for me, pass me an offer! THanks again
thxguy
A4 (B8 Platform) Discussion
11-12-2012 09:21 AM
