S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
1st -2nd gear transition?
Old 11-28-2003, 04:57 PM
New Member
kiwikid's Avatar
Default 1st -2nd gear transition?
What are owners thoughts on the shift.
Mines slightly clunky at the shifter (its fine going down)
I think the dealer will be hearing about it.
I've only 375kms on the beast.
I certainly hope its not the start of a citrus variety.
Old 11-28-2003, 05:01 PM
Junior Member
SelmerMk6's Avatar
I think the shifter should feel superb. Could you be more specific? Either way though check it out.
Old 11-28-2003, 05:10 PM
New Member
kiwikid's Avatar
Default Re: I think the shifter should feel superb. Could you be more specific? Either way though check it
Theres a slight clunk into 2nd at anything above say 4000rpm
Just in the shift not the engaging of the gear.
Yeh for sure I'll get it checked out on Monday.
Old 11-28-2003, 05:44 PM
Member
AlanL's Avatar
Get it checked - that shift should be as smooth as soft butter.
Old 11-28-2003, 05:53 PM
Junior Member
SelmerMk6's Avatar
Default A good number of people on this board have noted that a steeper learning curve applies to this car
when trying to achieve nice smooth shifts. They said that early on they really had to concentrate to achieve a smooth shift but eventually they adapted. These were experienced manual drivers so I wouldn't doubt it. You might want to try a search there were a number of threads on this issue. Personally,I always have trouble adapting to a new car so I am not a good bar from which to measure.
Old 11-28-2003, 05:57 PM
Member
AlanL's Avatar
Default True for the clutch, but the shifter gates for the 1-2 transition should be totally painless.
Performing a smooth shift (combination of clutch, gear change, throttle modulation) is another matter entirely
Old 11-28-2003, 05:59 PM
Junior Member
SelmerMk6's Avatar
Yeah I was having a little trouble understanding exactly where he was having a problem.
Old 11-28-2003, 06:50 PM
New Member
kiwikid's Avatar
Yeah, no its not so will check it in Monday
Old 11-29-2003, 08:26 AM
Junior Member
Inphidel's Avatar
Default Shift should be smooth-take it in.
I woulf get that checked asap. Mine was doing that and it was in the shop for 3 weeks.
Old 11-29-2003, 03:54 PM
Junior Member
Hoots's Avatar
I've noticed a rough transition from 1st to 2nd as well and I'm no beginner.
Quick Reply: 1st -2nd gear transition?
