Engine Code help needed .........
I picked my car up from the shop today and was advised that I have two stored codes.
I would like to post up the printout of the code sheet for all to see but I cannot seem to figure out how to do it. Can someone briefly explain? Thanks |
are you talking about "Check Engine Light" CEL codes?
If so, you can post them here or the VAG forum. If you can scan the print out just type in the information
For example: ------------------------------------------------ 1 Fault Found: "01826 - Sensor for Steering Angle (G85)" Supply Voltage Terminal 30 35-00 - - ------------------------------------------------ The information in the quotes is what we'll be looking for. |
Re: are you talking about "Check Engine Light" CEL codes?
OK here they are:
17979 - Left Engine Mount Solenoid Valve (N144): Short to Plus P1571 - 001 - Upper Limit Exceeded ------------------------------------------------ 16825 - EVAP Emission Control System: Incorrect Flow P0441 - 002 - Lower Limit Exceeded - MIL ON These are both of them. Any ideas? |
17979 - check the connector on the motor mount. did you poss hit something? reconnect if no damage. clear fault, perform ecm output check, recheck faults.
16825- clear fault run purge test engine 04 basic setting 070 run test see if system ok. |
Please do you have a diagram showing the position of this?
I have the engine mount error as well. Short circuit to B+. Not sure where to begin.
Have you fixed this too? |
