first audi, first problem :D... timing stuff of course
hi all,
im sorry i couldnt find a clear and definite answer to my question even after a quite lenghty quest!
so i just bought a b7 s4 with 150 000km and 2 days later, the head gasket blew so im going to have that done but if im going to have the engine removed, i might as well have the timing stuff done too (the guy who sold it to me said it has been done but i dont trust a single workd coming from that dishonest (...) so i prefer buying parts and return them if theyre not needed).
So, budget is tight and i found a reputable mechanic that will accept my parts i just need a detailed list of the parts i need. i only want to keep the car for a few months so ill only do the basic stuff (chains, tensioners and guides).
i know ill need 4 chains
im not sure about the tensioner part? how many? position?
im confused with the guide, how many of them are there? and whats their positions?
thanks very much !
thanks very much !
Here is a list of parts to consider replacing while you're in there
1 Engine Timing Chain Guide VAG-079109513C
1 Engine Timing Chain Tensioner FEB-25425
1 Engine Timing Chain Tensioner VAG-079109510M
1 Engine Timing Chain Tensioner FEB-25424
1 Engine Timing Chain Tensioner FEB-25418
1 Engine Timing Chain Tensioner VAG-079109507G
1 Engine Timing Chain 50038634
1 Engine Timing Chain 50038640
1 Engine Timing Chain 50038635
1 Engine Timing Chain 50038641
1 Engine Timing Chain Guide 059109469E <-- RS4 upgraded
1 Engine Timing Chain Guide VAG-079109510E
1 Engine Timing Chain Guide VAG-079109514B
1 Engine Timing Chain Guide VAG-059109469F <--RS4 upgraded
2 Camshaft Hex Head Collared Bolt M12x1.25x125 Mfg Part # N91086201
1 Cam Chain Tensioner Gasket - Cylinders 1-4 Mfg Part # 079109092B
1 Cam Chain Tensioner Gasket - Cylinders 5-8 Mfg Part # 079109091B
2 Camshaft Seal Mfg Part # 079109293C
1 Cam Chain Tensioner Gasket - Left Mfg Part #079131120A
1 Cam Chain Tensioner Gasket - Right Mfg Part # 079131120
1 Lower Timing Chain Tensioner Gasket - Center Mfg Part #079109139M
4 O-Ring 5x1.5 o-ring Mfg Part #N90638402 x4
also, rear main seal, and motor mounts. All together can be pieced together for about a grand
ThetaTau87
Audi Original "S" Cars
10-23-2007 12:19 PM
Whitjr
08-19-2007 03:26 AM
JoeyVee
2.7T V6 Discussion
07-11-2007 08:57 AM
BSK
10-23-2005 06:42 PM
