S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
first start of the morning.. cranks alot longer?
Old 09-17-2006, 09:23 AM
Junior Member
applejacks's Avatar
Default first start of the morning.. cranks alot longer?
first time i started the car each morning, it takes alot longer to turn over. cranks for a while. this cant be normal.. can it?
Old 09-17-2006, 10:40 AM
The Mystro S4's Avatar
Default Do you turn the key all the way on and wait 3 sec before cranking??
This will let your fuel pump build pressure first before cranking.
Old 09-17-2006, 03:01 PM
Banned
DrGP's Avatar
Default The battery could be going?
You never know how long a battery is sitting around before it is put into the car. I've had them go in as little as 1 yr.
Old 09-17-2006, 04:03 PM
40valves's Avatar
Default if you have a few miles on it, it can be the
plugs. It can be fuel (lack of), spark and/or you've got a totally clogged air filter. If it was a filter it would happen all the time so thats ruled out
Old 09-17-2006, 08:48 PM
Junior Member
applejacks's Avatar
thanks. i have about 30k.
Old 09-17-2006, 08:49 PM
Junior Member
applejacks's Avatar
interesting. thanks.
Junior Member
applejacks's Avatar
no i never do. i will try that. thanks.
Old 09-18-2006, 05:44 AM
Imola Ghost's Avatar
Default MIne seems to do the same thing, but it is almost every start.
I'm going to try waiting a couple seconds after I turn the ignition on before I crank it.
hanilanzi
02-24-2015 02:43 PM
DM-S4
12
03-10-2006 01:12 PM
Mtnboy7
Audi 100 / A6 (C4 Platform)
11-05-2003 06:54 AM
Unexplained Absence
11
12-21-2002 11:16 PM
wun-new-audi-ownr
08-30-2002 08:35 PM
Quick Reply: first start of the morning.. cranks alot longer?
