How do I change taillight? Can't seem to find opening to change...
I know I could take it in to the dealership, but I am going on a trip and would like to do it myself if possible. Thanks in advance.
Just Inside trunk lid small round access door yields access to single bolt
Pay attention to the rubber seal around the tail light so that when you put it back in it fits and seals properly.
2nd... you need to pull the entire retaining screw out... and then lift toward you. There are
three suction-knobs taht hold the light on the outside edge (so they would be on the right if you're working on the right light). Be careful not to pull the light hard because you'll pull the wiring with it.
All this advice is correct. Just verifying it since I changed my taillights.
