Lost power after oil filter housing gasket replacement
So I went to replace the oil filter housing gasket in the process of doing so I had to remove the intake manifold and some hoses and components attached to the throttlebody when I went to reassemble it and start it up and the car barley ran or idled so I gave it some gas and it revved but when the rev came back down it died. I looked back in the engine bay and the crankcase vent valve wasn’t on all the way so I made sure it was attached correctly then started it back up, the car started and idled better but now when I drive it, it has low power at high rpm’s and it make clicking noises out of the exhaust when you accelerate hard in 1-3rd and again has much less power then it did. What should I do or where could this issue be.
RASTAMN: is IRIE
01-11-2008 09:00 AM
JohnelP
02-04-2007 02:09 AM
Utah01S4
12-26-2005 12:09 PM
