Oil Change
Oil Change
I have owned my S4 since the first of the year. I have not had to change the oil because it has had consecutive warranty issues and the dealer has changed the oil over the past 15k miles. I have changed my oil in the past but not on this car. Is it easy to change or is it suggested to take it to a qualified lube shop?
?? The oil filter, is on top of the engine, as easy to get to as adding washer fluid.
It even has the cap torq spec on it.
The DIY oil change is a breeze. I've bought filters from PureMs, and they include the drain plug washer and filter cap o-ring.
If you don't want to remove the belly pan, use an oil extractor.
The car takes about 9.5 quarts of oil, so make sure you have plenty on hand.
Good luck.
Good luck.
SoSlow
14
12-31-2007 08:07 AM
sparkhill
RS4 (B7 Platform) Discussion
21
08-26-2006 05:07 PM
