[Long] 2010 Audi S4 scheduled maintenance
Hey folks,
As a prospective buyer of a new car I like to compare not only prices but also insurance costs and maintenance costs as I want to have an idea of how much the car will cost me after I purchase it, at least for the first few years. As part of that, I visited one of my local Audi dealers and asked about the regular mantainance schedule with pricing up to 105K miles. I thought I would post them here in case somebody else is looking for the same information.
This is for the 2010 Audi S4 3.0T S-Tronic/DSG. I'm pretty sure the prices will vary depending on where you are. I would expect the procedures to be simiar though.
It's my understanding that Audi Care covers the 15K (1-year mark), 25K (2-year mark), 35K (3-year mark) and 45K (4-year mark) services and costs $740 (MSRP). It does not cover for any in-between oil changes you may want to perform. Please correct me if I'm wrong.
Here's what I got:
<hr>
15K Maintenance
Parts:
(1) Engine Oil Filter (06E115562A) - $28.00
(1) Plug with Seal/O-Ring (N 0138157) - $1.63
(6.9) Synthetic Engine Oil (Quarts) (ZVW352540SBDSP) - $44.68
(1) Dust/Pollen Filter (8K0819439A) - $54.75
Total parts: $129.05
Labor
Engine Oil - change oil and replace filter
Service Reminder Display - reset
Dust and Pollen Filter - replace
Cooling System - check level, add if necessary
Exhaust System - check for damage, leaks
Engine On Board Diagnostics - check fault memory
Engine Compartment - check for leaks
Battery - check electrolyte level and add if necessary
Wiper/Washer/Headlight Washer - check adjustment and function, add
Wiper Arm Pivot Points - lubricate
Brake System - check for damage, leaks, pad thickness, fluid level
Transmission and final drive - check for leaks
Drive Shaft Boots - check
Doors - lubricate door hinge mechanisms
Underbody - check for damage and leaks
Road Test - check
Total labor: $192.00
Shop Supplies: $9.60
Total: $330.65 + tax
<hr>
25K Maintenance
Parts:
Total parts: $74.30
Labor
Tires and Spare - check for wear and damage, check pressure
Total labor: $108.00
Shop Supplies: $5.40
Total: $187.70 + tax
<hr>
35K Maintenance
Parts:
Labor
Lights - check all lights, check headlight adjustment
Tires and Spare - check for wear and damanage, check pressure, add
Power Steering Fluid - check, add if necessary
Road Test - check
Total labor: $276.00
Shop Supplies: $13.80
Total: $418.85 + tax
<hr>
45K Maintenance
Parts:
Total parts: $74.30
Labor
<hr>
END OF AUDI CARE COVERAGE
<hr>
55K Maintenance
Parts:
(1) Air Filter (8K0133843) - $33.75
(6) Spark Plugs (101905631F) - $150.75
Total parts: $313.55
Labor
Air Cleaner - clean housing, replace filter element
Spark Plugs - replace
Road Test - check
Total labor: $360.00
Shop Supplies: $18.00
Total: $691.55 + tax
<hr>
65K Maintenance
Parts:
Total parts: $74.30
Labor
<hr>
75K Maintenance
Parts:
Labor
Tires and Spare - check for wear and damange, check pressure
Ribbed V Belt - check condition
Road Test - check
<hr>
85K Maintenance
Parts:
Total parts: $74.30
Labor
Road Test - check
<hr>
95K Maintenance
Parts:
Labor
Road Test - check
<hr>
105K Maintenance
Parts:
Total parts: $74.30
Labor
Road Test - check
Ok, that's it! I hope this will be useful to someone else other than myself.
Regards,
Bruno.
Here's what I got:
<hr>
15K Maintenance
Parts:
Labor
Road Test - check
<hr>
25K Maintenance
Parts:
Total parts: $74.30
Labor
<hr>
35K Maintenance
Parts:
Labor
Road Test - check
<hr>
45K Maintenance
Parts:
Total parts: $74.30
Labor
<hr>
<hr>
55K Maintenance
Parts:
Labor
Road Test - check
<hr>
65K Maintenance
Parts:
Total parts: $74.30
Labor
<hr>
75K Maintenance
Parts:
Labor
Road Test - check
<hr>
85K Maintenance
Parts:
Total parts: $74.30
Labor
Road Test - check
<hr>
95K Maintenance
Parts:
Labor
Road Test - check
<hr>
105K Maintenance
Parts:
Total parts: $74.30
Labor
Road Test - check
Regards,
Bruno.
Looks good and accurate - I just still cannot get anyone to comment on the servicing of the DSG. Previous versions (which granted are very different from that in the S4) required a fuild change at 40K miles pretty promptly as they are very sensitive to viscosity break down as well as particles getting into the mechatronics and clogging the sensitive and tiny valves therein.
I have the service schedule listed out to 125K miles (which is just 2 servicings past yours here - one at 115K and the 125K) and nothing shows work needing to be performed at all on the DSG for the S4, there are service intervals listed for DSG, but explicitly state "A3 and TT only."
Disturbing to me, as the DSG maintenance on the A3 and TT (as well as several VW's with them) runs 400-900 dollars US, which would make AudiCare totally worth it for anyone with S-tronic if it followed similar maintenance intervals. I can't believe the fuild is good forever though, and seeing no mention is odd.
I saw your other comments on the subject and was hoping you would reply here too. Perhaps we should ask Audi/dealers directly about the new transmission (if you havent' done so already)?
I posed the same questions to their service guys who said it sounded like and oversight to them as well taking into account how DSG's are. They are researching it, no word yet though.
I'd almost want to know if someone from Europe or Canada can check with their dealers to see if the info differs.
Hey NWS4Guy,
I just remembered something. VM/Audi was working on a 7-speed dual dry clutch transmission. I clearly remember seeing something around that a while ago. I did some quick research and I found this:
Source: VW to debut 7-speed DSG at end of year (2007)
Here's another article:
Source: BorgWarner builds a better DSG (2007)
I would bet this transmission (or a variantion of it) made it to the S4. If it did, that would explain why there's no oil change mentioned in the S4 scheduled maintenance.
Bruno.
This year, Volkswagen is introducing a new-generation DSG with an extra gear [from 6] and dry clutches. The new seven-speed gearbox is more compact than the original and more efficient thanks in part to the dry clutches.
While BorgWarner's original DSG design has allowed for greater fuel-efficiency over traditional automatic transmissions, it has had room for improvement. The original design is a wet-clutch system, meaning the clutches operate in a bath of oil to keep temperatures down and eliminate wear. The oiling system requires large pumps to keep up the constant flow through the system and it also creates hydraulic drag that affects efficiency.
Bruno.
I'll link you some articles on our specific DSG, it's still a wet clutch, though they now have 2 different seperate oil types and loops to increase performance and decrease problems. One is a hydrolic oil for the mechatronics, the other is a hypoid oil that cools the system, provides the wet clutches their oil for resistance and also lubes the gears in the transmission.
Adding up the numbers of paying for all this out of pocket at each service interval vs. paying for it via Audi Care is as follow's...
Paying for each visit separately $1,124.90 + tax
Audi Care $740.00 + tax
So the Audi Care is a deal...and if someone from Audi ever tells us that our DSG's need to be serviced within the Audi Care mileage coverage...then it's even a a better deal.
What's the first service at 5,000miles run? If the above is correct, AudiCare doesn't cover this? I'm assuming it's just checking/filling the oil and some other steps?
