2011 Audi S4 Stock Boost Level ???
boost is boost. The peak SC boost is fixed by the pulleys and SC. The turbo boost is not, so can make more psi down low than up above if needed. block 436 (absolute manifold pressure) is for the B8 S4 for boost, was block 115 (requested and actual boost) on the B5 S4.
Bruce
Bruce
I doubt comf vs dynamic changes it. What I noticed about dynamic mode, aside from the red line shifting, is when steadily crusing in certain gears the RPMS are just a bit higher. I tested this out by driving in cruise at 60 mph and when I changed form dynamic to auto and the rpms dropped like 400 - then went back up 400 when i switched back to dynamic. It would be nice if they had a boost gage. That way, you know the boost and also if there is a boost problem. You will feel a boost issue when its obvious but not a subtle change so a gage makes things easier. With a gage you will also see when the real hot weather slightly affects the performace (even though it is intercooled). I really wont be modding this car much but A gage of some sort will be my next purchase.
yes, I have the s-tronic. The gear drop makes sense. Perhaps it goes into the higher gears at higher speeds in dynamic. I will have to test this out
Just a hypothesis...
