2011 S4 brakes vs A4
#11
Alas, like many other specifications, the AoA site has the wrong data listed. It appears they have the A4 specs listed under the S4.
The specs I listed for the brakes are the correct ones. I went out to measure to confirm on my S4. 13.6" front, 13" rear. Much larger than the A4 rotors.
#12
Are you implying that my analysis is incorrect? I don't know very much about the modifications made to brakes for track cars, admittedly, but I stand by my point that for street driving, brake upgrades are largely unimportant. If you can break traction on the tires, then adding bigger/higher friction brakes is not going to help you stop any faster. The principle reason that sports cars have these big fancy ventilated carbon composite brake systems is to prevent brake fade, and you have to be pushing a car fairly hard to actually come up against fading brakes.
I have only driven one vehicle that could benefit from better brakes, and that's a toyota tacoma with oversized, 4-ply tires that are simply much heavier than stock.
#13
#14
The weak link in absolute stopping distance is going to be the tires, and brakes cannot increase the amount of grip the tires have. The only possible way would be that bigger brakes provide a faster transfer of weight to the front tires, but the force effecting that transfer is still the frictional force between the tires and the road, as far as I can discern. Sure, bigger brakes may provide a stronger braking feel for the same amount of pedal applied, but in full-on braking, unless you're running tires that are either really, really heavy or really, really sticky, your tires are going to break traction before your brakes reach their maximum potential.
Me, personally, I don't push a car hard enough in every day driving to have any discernable brake fade. Maybe you do. I perhaps should have said "Track it OR Drive it very hard"
Regardless, I would like to hear what you mean by "more effective."
As I see it, you have more experience in practice than I do. I'm just going off of the theoretical and physical applications, as well as an extensive post on NASIOC that I can't now find about the topic.
TEB
20
10-22-2007 07:02 PM
BuStAmOvE7
01-25-2005 08:41 AM
Jay 4.2
02-25-2002 02:30 AM
