Audi Maintenance Costs are out of line
AUDI Maintenance costs are ridiculous,they want $406.61 for the 15K service?????, which is just oil and a pollen filter.... Come on!!!!!
Vehicle: S4 Engine: 3.0L Model Year: 2011 Transmission: DSG / S-tronic Interval: 15K Maintenance Engine Code: Parts Description Quantity Part Number Amount Dust/Pollen Filter 1 8K0819439A $24.31 Synthetic Engine Oil (Quarts) 6.9 ZVW352540S DSP $57.87 Engine Oil Filter 1 06E115562A $15.40 Plug with Seal/O-Ring 1 N 0138157 $3.30 Total Parts: $100.88 Labor Description Battery – check electrolyte level and add if necessary Brake System – check for damage, leaks, pad thickness, fluid level Cooling System – check level, add if necessary Cowl Drain – check for obstruction, clean if necessary Doors – lubricate door hinge mechanisms Drive Shaft Boots – check Engine Compartment – check for leaks Engine On Board Diagnostics – check fault memory Exhaust System – check for damage, leaks Lights – check all lights, check headlight adjustment Road Test – check Service Reminder Display – reset Snow Screen for Air Cleaner – clean Tires and Spare – check for wear and damage, check pressure and renewal date of tire set Transmission and final drive – check for leaks Underbody – check for damage and leaks Wiper Arm Pivot Points – lubricate Wiper/Washer/Headlight Washer – check adjustment and function, add fluid if necessary Dust and Pollen Filter – replace Engine Oil Filter - replace Plug with Seal/O-Ring - replace Synthetic Engine Oil - change Total Labor $260.00 Shop Supplies $18.20 Recycling Fee $0.00 Sales Tax (7%) $26.54 Total $405.61 |
Yes, this is why unless you have AudiCare, doing any work at the dealership is not the way to go.
$260 labor? Not even an hours work. |
Originally Posted by NWS4Guy
(Post 24244610)
Welcome to the business world. Historically dealers are always more no matter what the brand. But I doubt you would find a huge difference with BMW or Mercedes. May I recommend Kia =)
Originally Posted by sepangS4
(Post 24244643)
Originally Posted by Christo123
(Post 24244647)
Yes true, guess I was spoiled with the free BMW maintenance plan.
IMO if you are not going to do the work yourself, Audicare is the way to go.
Originally Posted by no cell
(Post 24244650)
It's not free. It's factored into the cost of the car.
There is NO such thing as free, there is always a cost associated and someone picks up the tab. |
(Post 24244655)
Exactly, not sure why people are basically buying the equivalent of AudiCare, but not being given the choice to buy it or not like Audi does, they claiming it's "free."
There is NO such thing as free, there is always a cost associated and someone picks up the tab. OK,OK, All please I don't want to turn this into a philosophical argument on what "Free" means thread. We all no nothing is truly free and yes BMW incorporates it int to the cost of the cars. |
Try the Porsche dealership. :)
I went with Audicare... just didn't have the time to deal with little things. |
