Strange Noise (kinda long post)
So, for some time now, when I start up my car, after a few moments, there's a strange noise coming from the dashboard. It's coming from the center all the way forward, just in front of the grille thing in the dashboard. It's a very noticeable (can even be heard over a loud radio), popping noise.
The can does not have to be driving to hear it, even when idling it happens. It only happens when the car is completely cold (ie. hasn't been driven for a at least many hours), so I hear it 99% of the time in the morning when I leave for work. The popping noise will occur anywhere from 5 or 6 to dozens of times and after 5 to 10 minutes, it goes away and isn't heard from until the car is started cold again.
I was thinking that perhaps it's due to expansion (as the car heats up) in the ventilation system and that there are a couple of parts that aren't fitting together as well as they should. I've tried adjusting the ventilation to direct the air to my face, feet, etc. and even tried turning the air system off completely ... but the sound is still there, regardless of the climate control settings.
Any thoughts? I'm at around 2000K miles, so I'm a bit off from my first service, but I may take it in earlier to take care of this. I just don't want to be without my car. PLUS ... it seems like any time I've got something quirky that's wrong with a car, service techs can never "recreate" what I'm getting.
Thanks!
Thanks!
I will pay extra attention but I haven't experienced anything similar. I live in Buffalo so I have already experienced some "cold" starts. Like I said I will listen carefully and let you know.
Sounde very odd, the only sound I get is when I open the driver's door, I can her a mechanical whizz sound coming from the passenger's rear side, which is the fuel pump pre-loading to start the car (since it's direct injection it takes a lot of pressure).
This is what I hear too and may be what you are describing Chris. I hear it every time in the morning when I get into my car.
Hmmm ... I don't know. It's a very "plastic-y" sound. It doesn't sound mechanical at all and it's most certainly from the front and center of the dash board. It's like a quick, loud popping/snapping sound. I guess I just need to take it in ...
No, what I am referring to is the whirr of a little motor, nothing pops, nothing plasticy. Sounds like something loose on the dash, or steering if it's coming from where you say - the fuel pump I am hearing is in the rear of the car in the gas tank.
My bet is the stepper motor for the heater system - it opens the hot air mix inlet in " steps " as the engine coolant temperature rises so that you are not blown fridgid air from the floor ducts as you first drive off . It makes a series of subtle plasticky pop/click and even faint groan sounds as it does so. It's located where you describe it. Most Audi's do this .
http://en.wikipedia.org/wiki/Stepper_motor
I never hear any loud sounds with my S4. I do hear the fuel pump whirr when I first unlock the doors, but that's it. No loud pops or cracks. I think you should have the dealer take a look at it.
