Complete Interior LED Kit Error Free / Plug & Play / Ships FREE - includes DIY/Review
#61
Audiworld Basic Sponsor
White/Yellow/Halogen/Strobe/Flash plug and play fogs:
Dual Color LED Fog [1 bulb 2 colors] Choose between a Clean White & Hyper 3000k Yellow at anytime | deAutoLED
-Plug and play
-Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
-BRIGHT – this is not just a novelty bulb
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
-SAFE – more light on the sides and down the road when dark or in bad weather conditions
-The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
https://www.youtube.com/watch?v=T-fex4DUPSg
3 colors:
-Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
-Clean White 5500k that matches our LED & HID Headlights
-Halogen 4300k that matches OEM
Video cycling quickly through colors AND different strobe/flash features:
https://www.youtube.com/watch?v=bQG0gRKGFk0
INFO:
-THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
*Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
Attachment 104952
Attachment 104953
UPDATED FAQ
Is there a lifetime warranty?
YES! As always this comes with a True Lifetime Warranty!
Will your fogs keep changing colors if you use them as cornering lights?
The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
How does this work with the coming home feature?
This works just like OEM. It will always be the default color of white.
What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
Can these turn 360 degrees?
Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
Are these as bright as your single color de360 fogs?
While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
Can you bypass the strobe feature?
Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Some more fun shots - in the rain:
Attachment 104954
White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
Attachment 104955
Attachment 104956
And switch back to clean white:
Attachment 104957
-Plug and play
3 colors:
INFO:
Attachment 104952
Attachment 104953
UPDATED FAQ
Attachment 105060
Attachment 105061
Attachment 105062
Attachment 105063
Attachment 104954
Attachment 104955
Attachment 104956
Attachment 104957
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
#62
No joke very bright hyper yellow 3K Plasma Fogs:
Just Yellow Hyper 3000k Plasma Fog LED Kit | deAutoLED
This 3K hyper-yellow 3K is also available in the switchback white/yellow model:
And solid white:
LED Headlight or Fog Bulb Kit - Error Free - Plug & Play | deAutoLED
Attachment 105037
-easy install
-lifetime warranty
-plug and play
And solid white:
Attachment 105037
-easy install
-lifetime warranty
-plug and play
#63
Are you ready for Halloween, Fall and the winter?
Get ready with Orange footwells
Perfect Fall weather to install LEDs for the darker winter nights
www.deAutoLED.com
Attachment 105024
www.deAutoLED.com
Attachment 105024
#64
SHOP NOW - GREAT WEATHER - HALLOWEEN SALE
www.deAutoLED.com
Attachment 105021
We have been rated some of the brightest LEDs that actually work with your Audi electronics.
-don’t waste time guessing what will work or look good: we test our LEDs to be bright and work
-price is competitive – when compared to what you get some brands are higher priced and not brighter
-24/7 customer service ready to help
-FREE shipping within the US and quick delivery
www.deAutoLED.com
Attachment 105021
#65
#66
#67
Try out the best LEDs for your car - tested - works - lifetime warranty and free shipping within the US
www.deAutoLED.com
www.deAutoLED.com
#68
Shop now:
www.deAutoLED.com
LEDs that work in your car
Contact us for help - we reply within the hour 24/7:
https://deautokey.com/contact
www.deAutoLED.com
#69
#70
Anyone doing Green footwells for the month of March?
-Plug & Play
-Error Free
Check out our RGB Color changers - all LED footwell models can be found here:
https://deautokey.com/product/mk7-gt...-footwell-leds
contact us if you have questions:
[URL unfurl="true"]https://deautokey.com/contact
Attachment 104907
Attachment 104908
Attachment 104909
-Plug & Play
-Error Free
Attachment 104907
Attachment 104908
Attachment 104909
