S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Direct Injection sound?
Old 10-24-2010, 04:52 PM
98ttsupra's Avatar
Default Direct Injection sound?
I had the hood open for the first time with the engine running today. My first thought was that the engine sounds horrible, but thought "well, I guess that's what direct injection sounds like". A few minutes later, I started to realize that the clattering seemed louder from the left side of the engine. Is this normal?
Old 10-24-2010, 05:02 PM
NWS4Guy's Avatar
Here's normal idle, it starts in the video on cold/fast idle, then settles into a typical warm idle sound.
http://www.youtube.com/watch?v=q-wFquleIi4
Old 10-24-2010, 05:22 PM
98ttsupra's Avatar
Thanks for the video, that's exactly what I'm hearing with my S4! Any idea what all that clattering is on the left side? If it was from direct injection, wouldn't the sound be uniform on both sides of the engine?
Old 10-24-2010, 06:37 PM
NWS4Guy's Avatar
Some of the sound is the injectors, you are right, with direct injection, the injectors have to run very high PSI, so it sounds a bit like a diesel. The sound on the right is masked more most likely as the steering server pump and A/C are over there, the right side has only really the idler pulley, tensioner and alternator. That side of the compartment is pretty open for sound as well where the other side has so much packed it helps absord some noise.
Old 04-13-2011, 03:10 PM
phatalbert's Avatar
Default Should I be worried?
Does this sound normal?
http://www.youtube.com/watch?v=SqjyOGqGj_4
Old 04-13-2011, 06:53 PM
SCHALTHEBELKNAUF's Avatar
If you mean left side when looking at the engine from the front (ie the passenger side of the car) then the noise is probably louder because the fuel pump is located on that side of the engine and is mechanically driven off of the camshaft.
Old 04-13-2011, 08:21 PM
dr bryan's Avatar
I'm no expert but that sounds louder than normal to me...
Old 04-14-2011, 05:33 AM
FatalBert's Avatar
Well the vid was captured with a droid, might have a more sensitive mic. But I also noticed that the black hose that runs above the spark plugs on the left side seems to be shaking with the noise as well. Not sure if thats normal. I'll be bringing it back to the dealer today to be sure.
Old 04-14-2011, 05:37 AM
skiracerblah's Avatar
I always wondered if its normal for the engine and the rubber line on the left side of the engine to vibrate like that.
projek_01
Q5/SQ5 MKI (8R) Discussion
10
01-04-2019 09:41 AM
krisix
10-13-2017 01:47 PM
nilreb
07-15-2012 01:49 AM
iamaudi.com
A4 (B8 Platform) Discussion
09-28-2009 01:05 PM
cerfsud
9
01-14-2009 11:23 PM
Quick Reply: Direct Injection sound?
