Mute phone mic
Anyone know if you can mute the bluetooth phone mic when on a call? I spend alot of time on telecons and need to be able to do this. I could not find anything in the owners manual.
Thanks, Greg 2010 S4 Ice Silver, 6MT, Prestige, Black Napa, ADS, DA, Carbon Fiber 2005 Dodge Ram 2500 Larime 4x4 turbo desiel, 6MT 2003 Lexus GX470 Previous 2002 A4 1.8T Quattro, 5MT, sport 2000 A6 2.7T, 6MT 1994 Acura GSR 4 door 5MT 1993 Mazda MX6 1991 Eagle Talon, AWD 5MT 1988 Pontiac Grand Am SE 1984 Buick Skyhawk T-Type 5MT 1971 VW Fastback 4MT |
While on the phone screen in the MMI, hit the "Setup" button. I think it's in there. Were you looking in the owner's manual or the separate MMI user's manual? It may be in the latter.
It may not be possible. I've looked around the MMI for this option too. Perhaps you can mute the phone itself? (not ideal, I know)
Originally Posted by tgdA4
(Post 23868363)
Tel -> Options
When you have the phone active in a call so you see the MMI change to the phone screen, hit the corner key that says options, then keep it on that screen. You can scroll through the 3 options there, and choose mute with the nav wheel and click it.
Once I type it out it sounds like a lot, but it's really easy. I think there's also a way to mute with the scroll wheel / mode button on the left of the steering wheel, but I just use the nav wheel. |
One thing to watch out for: I think the MMI Mute option stays where you set it. If you turn mute on and then hang up, it will still be on mute the next call you take. This drove me nuts when I took delivery of the car last Friday and found I couldn't answer a call. Later on in my garage testing it, I eventually found the Mute option and turned it off.
Would have been nice if Mute was on one of the four corners of the Telephone screen or if there was some obvious indication on the phone screen that you are Muted. |
Thanks for the info and the warning. It works as described above.
Greg |
Originally Posted by derazmus
(Post 23868680)
Would have been nice if Mute was on one of the four corners of the Telephone screen or if there was some obvious indication on the phone screen that you are Muted. John |
