S4 Break-in issues
S4 Break-in issues
Hey Guys, hoping to pick anyones brain here. I had my '06 S4 rebuilt and its seems like the break in process did not go so well. From what I understand, the mechanic made a mistake and put in synthetic oil after the rebuild and it would seem that the rings did not seat properly. Did a compression test and I am 120psi across all 8 cylinders. Any suggestions on what I might be able to do to save me from doing another rebuild? Perhaps a thinner oil to get some friction back and hopefully re-seat the rings? Going through about 1 qt / tank of gas right now. Appreciate any help!
Cheers
Cheers
Banned
Cheers
Cheers
So, this topic has been beaten to death. I can not comment on how to deal with your current situation but I can comment on how to break in a new or rebuilt engine. As has been documented on this forum, the motorman method is flawed. All the points DrGP makes, needing pressure and undue wear ESPECIALLY ON A NEW ENGINE by running to the redline are correct. Someone a while back posted a very thoughtful article that I believe was in Popular Mechanics and it was based on science and not anecdotal evidence of a few people on a forum. What it says it, you do need to run at WOT once warmed during breakin, HOWEVER, to not let the engine initially get above maybe 3000rpm. As miles build, you can start to increase thenshirt point. High revs are likely to prematurely wear a new engine but pressure from WOT does help eat things. Also, to be clear, engine warm is not coolant temperature up to operating level, it is oil temperature up to operating temperature. This takes maybe 15 minutes on a warm day. Hope this helps. So motorman has the right issues, the solution is off though.
Banned
Not sure it works
You actually don't know that. Given the number of S4's out there, we don't have anything close to a statistically significant sample to make that statement. We also have what is likely dramatic bias in the sample.
Finally, a significant number of oil burning engines will negatively impact resale value of a brand. Having good resale is critical to offering competitive lease prices. Do you believe that Audi, who does have the data, would not modify their break in procedure if it resulted in higher resale.
Banned
Snuckley
A4 (B8 Platform) Discussion
05-05-2012 10:14 AM
talltorontoguy
12v V6 Discussion
10
09-17-2005 07:23 PM
