Sports Differential Fault after battery replacement
I have a 2012 Audi S4,i was gone for a few months and came back to a dead battery. I replaced it with an OEM battery from Audi ( I put it in myself so i did not do any adaptations or anything). And as soon as the car started up the sports diff fault light came on. I have no other issues and its seems to drive normally.
Prior to me leaving i had no issues with the Sports Diff.
Are their extra steps that i need to do?
Unfortunately I do not. There are no other problems with the car. I can select the different modes i.e sport etc... and it does not seem like there are any problems. I have scheduled maintenance tomorrow anyway... Ill see what their scan reveals. I am hoping the car just thinks a new diff was installed or something....
I am not sure what my options are.... I dont notice any difference while driving it.
It blows my mind that this is the second one in 60k miles.... no more audi i guess
Now the fault appears to be intermittent. They did not flash the ECU so it still had the APR Tune when they did the Pressure sensor replacement procedure... I am not sure what the battery dying... the tune on the ECU and this fault have in common but i have to believe that Diff didnt suddenly go bad after sitting for 6 months. It looks to be a coding or electrical issue. I am thinking about buying a VAGCOM reader... any one have a brand or model that they prefer? I have seen some bluetooth ones on Amazon...
I isolated the issue to some corrosion on the wiring harness that terminates in the battery well. After i cleaned off the battery ground wire and the remaining connections it cleared the fault and never showed up again. I suggest if you have no leaks in your sports diff that you do that before taking it to the dealer. Dealer was going to charge me 8k for a new sports diff and had not even checked the signal wiring.
This is ridiculous
Shocking, spend all that money, when it was a corroded electrical connection.
I wonder how often this sort of thing goes on
AUDIos my migos
02-01-2021 07:31 AM
mecgmecg
A4 (B8 Platform) Discussion
06-25-2020 06:23 AM
rellascout
9
08-30-2017 09:40 AM
