Trunk won't open with remote
Is there any setting that you guys know about that would prevent the truck from opening via the remote? Whenever I press the trunk button the lights blink but the trunk won't open. It works fine with the release in the driver's door, and also if I touch the button on the trunk lid itself.
Anything I should check before taking it into the dealer? |
IIRC, I believe there's a menu option in the MMI Car>Car Systems>Vehicle settings that allows you to control the truck lock with the key.
Also check that you haven't hit the Valet button accidentally in the glove box. I know that disables the remote open, but can't remember if it affects the other methods.
I would suggest trying the 2nd remote that came with the car.
Originally Posted by LYKUNO
(Post 24547240)
If both remotes don't work try disconnecting the car battery. the elec system may reset itself when reconnected. modern cars and smart phones are computers. sometimes they lock up and have to be reset. best. |
Originally Posted by snagitseven
(Post 24547149)
Originally Posted by RobC
(Post 24547201)
Valet mode only stops the trunk from being opened IIRC. It has nothing to do about driving the car. Looks like a trip to the dealer is in order if the other fixes haven't worked.
I know with my remote I have to push and hold, but I am pretty sure you have tried that. |
Originally Posted by ob_1jr
(Post 24548123)
Glad it worked for you. I rarely use my remote buttons, but there are a few exceptions.
