[Advice Required] Trunk Subwoofer Replacement Using Stock Amp
Hey guys,
My B&O sub has decided to leave the chat. I am replacing it with the Ampire Bold 6.5 as it was the easiest to get in to Australia out of all I could locate on @Bobby Kinstle 's spreadsheet. (Would be awesome if he is the man to help here). I am just wondering how I go about wiring it back in to the stock amp if I wire it the same as the current woofer that is in there, or if I only use one input and wire parallel? If I could just get told what colours to plug where that would be awesome. Cheers in advance. |
Originally Posted by apprehends
(Post 25906057)
THe stock subwoofer has two amplifiers one for each voice coil. It can drive 4 ohms each, so buy a 4 ohm DVC subwoofer with the highest possible efficiency. The ampire has very low efficiency and you are never going to get satisfactory output from the factory sub. Looks for something with an efficiency closer to 90dB like the Kicker Comp C10
Originally Posted by Bobby Kinstle
(Post 25906106)
I have an avant so only the trunk one under the spare wheel. |
Comp C10 works fine with stock amp/wiring, it tightens up the sound quite abit compared to stock (thx apprehends for the advice a few years ago :)).
But this is my experience on a sedan with free air installation, not sure if that assessment would change with a wagon however. |
Originally Posted by pleedell
(Post 25906137)
But this is my experience on a sedan with free air installation, not sure if that assessment would change with a wagon however. Yeah I can't go Comp C10 for 2 reasons: 1. I have a wagon... 2. The only way to get them easily in Australia is to order one already installed in a box and remove it. |
Unfortunately there aren't a lot of good options for the wagon unless you are willing to have a sub box. None of the 6.5" subwoofer drivers are high enough efficiency to deliver a good output from the factory amp.
(Post 25906331)
I'm not concerned about it being a good option as long as it's comparable to the stock as my stock one **** itself. I pretty much just want to wire the Ampire one, in the stock box, regardless of performance and was wondering what wires to run where on the sub. I was doing some testing on the wiring tonight and for some reason the orange and yellow wires don't have any sort of power running through them, however, the green and black do. I will be having a custom sub and aftermarket amp installed at some point, but I need a temp solution just to get some sort of subwoofer back in the car. |
OK let me put it in clearer terms, the ampire woofer output is half as loud as the stock sub at the same power level.
