2 Quick Questions on S4 parts.
Hey gang had a few quick questions.
1. Does your USB Port #1 which is located under the climate controls and next to the 12V power port light up like the USB #2 port located under the middle console holder? My #1 USB port doesn't but my #2 port does light up. 2. Anyone know the rim side width of the 18" OEM wheels on the S4? I know the tires are 8.5 width according to Tirerack so wanted to see if the rims are also 8 or 8.5 width. Thanks! |
1. I took delivery in late March, when both USB ports were still located beneath the armrest. So both light up on mine. The move of port #1 to beneath the climate controls was a rather recent mid-production-run change, and I suspect it was either done as cheaply as possible (hence no light) or that it was a conscious decision made so that drivers weren't forced to stare a somewhat out of place light in the face when driving at night. (The 12V aux tucked away down there doesn't light up either.)
2. I had thought the stock 18" weels were 8" width, but I'm only about 60% sure of that. What I can tell you is that my aftermarket winters are 8" wide and they're working just fine. |
Originally Posted by mplsbrian
(Post 25067317)
2. I had thought the stock 18" weels were 8" width, but I'm only about 60% sure of that. What I can tell you is that my aftermarket winters are 8" wide and they're working just fine. Interesting on the USB port that was moved there...didn't know that was a change. |
(Post 25067317)
