S4 (B9 Platform) Discussion Discussion forum for the B9 Audi S4 produced from 2016-
Shutting off engne when parking
Old 12-09-2017, 06:17 AM
Sobeit's Avatar
Default Shutting off engne when parking
Guys, is it bad if I just press "Start/Stop Engine" button to shut down the engine *without* putting the tranny in Park first? I remember reading a thread about that but can't seem to find it. Your input/thoughts is appreciated.
Old 12-09-2017, 07:16 PM
heisnuts's Avatar
If you set the parking brake first there shouldn’t be a problem. If you don’t and you are on an incline the car might roll a little bit before the park gear holds the car.
You could also open the drivers door after taking off your seat belt (with the engine running) and the car will set the parking brake for you.
Old 12-10-2017, 03:39 AM
Horrgakx's Avatar
I just press the OFF button and the car goes into Park automatically. I don't usually set the parking brake unless I'm on a hill.
Old 12-12-2017, 05:37 AM
markcincinnati's Avatar
I always set the parking brake. Shutting off the car "in gear" is no problem, as far as I know -- the car automatically goes into park if you forget. The setting of the parking brake eliminates the "clunk" which can sometimes happen when you get in the car after it has been ONLY put in park. However, other than the clunk, I would assume there is no mandatory requirement to set the EPB. Since it automatically releases, I can't see any downside to always setting it, however.
Personal preference.
jahummel
05-20-2019 05:56 AM
heisnuts
07-23-2017 03:01 PM
topgun77
TT (Mk3) Discussion
07-27-2016 07:45 AM
kevinsong
A6 (C7 Platform) Discussion
34
02-26-2014 08:42 AM
Shef
09-19-2012 05:46 PM
Quick Reply: Shutting off engne when parking
