Driver door rattle
Driver door rattle
Well, it took 5K miles, but I now have a rattle inside the driver door. Any tips or DIY links to removing the driver door panel to get inside the door?
DaveGee
DaveGee
I noticed mine started doing the same sometime within the past 1000 miles or so.. I have 10,500 on mine now. Its a faint rattle - if it gets to be more annoying, I'll have the dealer look at it next time its in.
I've had 2 sources of rattles in my doors. The first was a piece of plastic that broke off the stock light at the bottom of the door during the audi ring light installation at port. All I did was pry the bottom of the door apart and it fell out. The other has been where the lighting is recessed in the door panel, a little pressure on it seems to have put it back into place and fixed that as well. Check out the following link if you want to disassemble the door. https://www.audiworld.com/forums/a4-...b9-a4-2915685/
CincyQuattro
08-16-2010 06:01 AM
pr0digy30
07-16-2007 01:30 PM
SCarGo02
13
08-19-2003 01:26 PM
