The tire issue
The tire issue
Hi, guys. I found my S4 front right tire seems a little bit flatter(Squash) than the left one. I check the tire pressure are total same, and I use the Continental DWS 06 all season tire. Is the tire has some problem? Or because right side is heavier than the left? Thanks a lot!
While I am sure there is a small weight difference between L and R*, if tire pressures are correct on both sides you should not be able to notice any difference based on the tires. Can you provide a photo?
* = fun fact, a good alignment specialist who works on performance cars will often even check & set alignment with you or a similar-to-you sized person sitting in the driver's seat to create extra weight in the cockpit area
C-Nutts
Wheels & Tires Discussion
12-10-2003 02:23 PM
planux
07-22-2003 04:04 AM
whealy
09-05-2000 02:25 PM
