Oil consumption?
Oil consumption?
I always monitor my oil level as I had a 2011 A4 that burned oil like crazy. It was a pain in the ***. I just noticed my oil level dropped for the first time. I have 4,400 miles on the car. Is this normal?
From the reading I've done, nobody has reported oil consumption so far. You will want to make sure you follow the proper steps to check the oil, which is to make sure the car is warm, turn the engine off, wait approx 2 minutes then turn only the ignition (not the engine) back on and check the oil level. If you try that and it's still low then I would just top it off and see if it happens again before you worry too much.
It looks you went to measure while the engine is running. Try it with the engine off?
Check owners on proper procedure to check oil. Then make sure to drive the SNOT OUT OF IT... The rings may not have sealed correctly. These cars like to be driven not babied. I've never had any vehicle 2 or 4 wheeled that used oil. But I've never babied any of my cars or bikes.. JMO
That is completely normal. Don't be surprised if you check it again a few days later and it has moved up a little to the full line or just below.
Totally NORMAL.
Again, make SURE you are using the correct Oil Checking procedure per the owner's manual, and make certain you are using that methodology consistently for accurate results.
gr
gr
JAH
11
04-20-2021 03:15 AM
dxben
RS4 (B7 Platform) Discussion
07-17-2006 06:15 PM
I getting a bit concerned about my oil consumption. What is your oil consumption for say 5k miles? I
2.7Twin
18
01-11-2004 07:52 PM
Broker
08-06-2002 06:11 PM
GLQuattro
02-19-2001 03:48 AM
