S4 8-speed question
#31
I've never tried in on my BMW, but my guess is LC basically overrides the cars natural programming to prevent the brake and gas to be pressed at the same time. It's like how the revs are limited on the Audi when it's in neutral since it's pointless to be reving the engine.
It would technically still just be stalling the converter, but that's how LC has been on auto's since the beginning of time. In pre-computer days it engaged reverse and 1st at the same time to lock the transmission (they called it a transmission brake back then).
It's possible Audi just doesn't enable it since it works radically different than on the DSG, and the purists will complain it's not "legitimately LC".
#32
I've never tried in on my BMW, but my guess is LC basically overrides the cars natural programming to prevent the brake and gas to be pressed at the same time. It's like how the revs are limited on the Audi when it's in neutral since it's pointless to be reving the engine. It would technically still just be stalling the converter, but that's how LC has been on auto's since the beginning of time.
#33
All these modern vehicles are drive by wire (throttle body isn't actually connect to the throttle petal directly). When traction control kicks in, the throttle closes even though you have the petal to the floor.
Without LC enabled, I'd assume they would prevent full throttle with the brake fully depressed to prevent the engine from overpowering the brakes (more of an issue now vehicles have higher horsepower and not naturally aspirated).
You can check out YouTube videos on the BMW. It was standard on my 2016 BMW 340 (but like I said, I haven't used it since it is insanely hard on the torque converter). Nice thing about the turbo Audi/BMW 3.0L is at that 3k stall point, the engine is at high boost, high torque so the need to be at 5k rpm when the clutch dumps (like a non-turbo) isn't really a concern.
#35
Is it really even possible for any normal stock car to have engines that can overpower the brakes?
#37
My understanding (from the past) was the engine could not overpower the brakes for safety reasons. Now that vehicles are drive by wire, the throttle is 100% electronically controlled by the ECU, I doubt it can ever happen. Great example is when traction control kicks in, and no matter how hard you plant the gas, the engine stops reving. I just don't know how they deal with launch control.
#38
Has Audi ever said that or was this speculation from reviewers and/or people? I have never read an official claim and can only guess this was a cost cutting measure and nothing else.
#39
This information was relayed by Audi reps to nearly every reviewer when the S4 and S5 were introduced. I even watched an S4 review on Youtube that had an interview with an AoA product planner who explicitly stated that the ZF8 was chosen over a DSG for its low-speed smoothness and because the new 3.0T had too much torque for existing DSGs. However, I agree that the most likely reason is that Audi wanted to limit R&D and/or manufacturing expenses.
#40
The ZF8 was introduced to replace the ZF6 as a means for increased efficiency and mileage while supporting large input torque loads. Considering the range of vehicles/brands that get this transmission (Dodge trucks, MB, BMW and Audi vehicles, etc), it makes more financial sense to buy a transmission from a company that specialize in trannies vs trying to re-invent that wheel.
