S4 (B9 Platform) Discussion Discussion forum for the B9 Audi S4 produced from 2016-
Single or Double Tire Replacement
Old 09-22-2017, 03:59 PM
IDMS4's Avatar
Default Single or Double Tire Replacement
Just got my 2nd nail in 5 months, this time it's the front driver's side tire. No leaking and tire pressure is holding up fine. I'm going to have to get it replaced, however, I currently have 2,633 miles on the S4, can I get away with just replacing the affected tire or do I need to replace both front tires?
Old 09-23-2017, 02:54 AM
heisnuts's Avatar
If you are already planning on buying a new tire, I would pull out the nail first (when at the tire shop already). Since it is not leaking now, there is a chance it did not go through the tire and will save you a replacement. Assuming it did go through, one tire would be fine since I cannot believe you would have worn the other three tires more than 1/32 with the low miles you have on them.
Old 09-23-2017, 08:01 AM
Glisse's Avatar
Agree with Heisnuts re. mileage not significant enough to warrant replacing both tyres on the same axle. What I may do is move the rears to the front axle, and use the new tyre on the rear along with the existing front passenger wheel/tyre. But even that is probably unnecessary.
Old 09-23-2017, 08:52 AM
newmoon's Avatar
If the nail is not too close to the edge, you could just get it plugged and patched from the inside for around $25-30 (involves remounting and rebalancing the tire). That is what they would do if you had a road hazard warranty.
Lemongello
Wheels & Tires Discussion
01-23-2018 09:45 AM
bluetail
A4 (B9 Platform) Discussion
11
07-01-2016 05:46 AM
fredbourgeoismtl
01-27-2009 07:41 AM
AR 4 S.S.S.
Audi allroad
05-18-2006 06:57 AM
S4-GTR
12
09-23-2004 08:25 AM
Quick Reply: Single or Double Tire Replacement
