Top View Camera Glitch?
#31
I wanted to warn B9 S4 owners that the latest fix for this issue is not for us. I talked to the dealership, they gave a tech the instructions from the person in the B9 S5 that had it done and I was told it could be done. I just went to have this done and was then told that it is not applicable for B9 S4 owners and that our fix for this is TBD. They found the recent TSB for the instructions I gave them and confirmed with Audi that this does not work on the B9 S4 platform, due to incompatible software. I will update this if/when I find anything out...
#32
As mentioned by ScoopMan and BriedFox, the PSS 2049414 is a Pending Service Solution and not applicable to the S4 line.
This was from my dealer today after providing that to him:
That is the Pending Service Solution that we spoke about and your car has already been added to the list. Once they are finished with the update, the will create a service bulletin that will guide the technicians on how to perform the update with the correct codes.
#33
#34
I don't know. I went in to have it done, but the tech called Audi beforehand to make sure that the firmware update was applicable to my S4. Audi told him that it was not applicable and that the one for the S4 is still TBD. Maybe the fix will be done when they release the TSB...
#36
It's ridiculous that it took this long to remedy, but you can go get this fixed now when able.
#37
Another success story here. Had my firmware update performed yesterday to the new 1316 file version. And it appears to have resolved the issue.
#38
Has anyone had their firmware updates who has used OBDeleven to make changes? Did the update reset everything to default? No big deal to go back through and re-do everything just curious
#39
FIXED
I also have had the update applied to my S4. I can confirm that it can be done to version 1118 to upgrade to 1316. My car was probably one of the earliest to be affected by the bug as it was built in July 2017. I also had the preset TSB applied with no issues. My OBDeleven change to show gear numbers in the VC also remained. Phone connected via Bluetooth and all other defaults look unaffected. FINALLY.
Now if they can just fix the incessant creaking in the rear passenger area C-pillar, I think I will be as happy as a clam.
Thanks to all that post here!
#40
I haven't noticed that any of my 10 or so OBDEleven changes were reset or reverted. It's just like I had before, but with a new software version.
