!!!***NO BOOST and BLACK SMOKE***!!!
Old 06-07-2007, 06:52 AM
New Member
Jaster's Avatar
Default !!!***NO BOOST and BLACK SMOKE***!!!
Well, here goes. Normal driving in vac, no problem. As soon as I get into boost range, the car hesitates a bit and there is a little black smoke out the exhaust, from what I can see. No other mods to the car but the APR chip and FMIC. CEL came on and went away, then came on again. I recently had it checked and P1127 and P1129 are the codes - "Manufacturer controlled Fuel and Air metering". I am about to order the O2 sensors to replace them, but why will the car hesitate the way it does only at boost, blown turbos, boost leak? The car drives fine in vacuum. Happened yesterday, so I did not check hoses for oil indicating the blown turbo. Any feedback is appreciated.
What is going on and what do I need to do to fix?
2000 S4 with 93000 miles. Timing belt maintenance was done a couple months back.
Old 06-07-2007, 07:00 AM
Junior Member
B5QShip | CFDQ's Avatar
Default Sounds to me like a massive boost leak. Black smoke is probably because it's running pig rich
when the car is trying to make boost. Pressure test asap. Likely culprit is an IC hose. How black is black and how much smoke do you see? From your description it sounds worse than just a car running rich.
Blown turbos will give you white or bluish smoke.
Old 06-07-2007, 07:01 AM
Audiworld Sponsor
DAP@EPL's Avatar
Second that.
Old 06-07-2007, 07:18 AM
ChucktownS4's Avatar
sounds like you pop'd off a ic pipe/hose or check the TBB
StreetCrawler(Cole)
07-31-2006 09:57 AM
The Crapple
Audi Original "S" Cars
02-03-2006 04:24 PM
S4@last!::Now B7 RS4
09-15-2004 07:41 PM
back2black
06-21-2004 08:38 PM
Planet_Acid
08-06-2003 02:03 PM
Quick Reply: !!!***NO BOOST and BLACK SMOKE***!!!
