150lb Engine that produces 800 HP++
* There are no odd or brand new parts within the cylinder. All the parts are proven designs used in reciprocating engines.
* The entire engine acts as a heat sink and a radiator. It is both air and oil cooled.
* There is no thrust loading on piston skirts.
* Pistons do not touch the cylinder walls, only the rings do.
* Pistons travel only the same direction. No reciprocation, only stop and go.
* There is high rpm potential for all of these reasons.
* There are no cylinder heads, no cam shaft, no valves (the ME is equivalent to the bottom end of a reciprocating engine).
* Intake compression and power stroke and exhaust stroke events are happening all at the same time, so there are no load strokes.<ul><li><a href="http://www.leftlanenews.com/2006/04/24/massive-yet-tiny-engine-promises-big-things/#more-2463">MYT and massive HP</a></li></ul>
Nate (ETKA+Scumbag)
06-18-2007 07:20 PM
Bada Bing
A4 (B7 Platform) Discussion
111
02-16-2007 06:57 AM
jmsod
55
05-26-2005 06:34 AM
AndrewM (azdaspeed3)
05-04-2000 05:18 AM
