2.7t Crank seal leaks after replacement.
Hello
Fairly new owner to this vehicle I picked it up a couple months ago. Out of the view i dumped about a half to a quart of oil b psck. Took it to the garage and it seemed to be that the front crank seal blew. Oil 3verywhere all over timing components and a good puddle under the crank gear.
This car is st 202k had tons of maintenance and t belt all gaskets and seals supposedly at 186 and 192k between the two services.
Tore it all down replaced
-OEM Tensioning damper
- OEM Tensioner Roller- OEM Relay Roller- OEM Tensioner Lever Arm- OEM Timing Belt- OEM Behr Thermostat with O-Ring- OEM Serpentine Belt- All Metal Water Pump-Elring front crank seal Valve cover gasket
I didnt reappce cam seals as they sidmt seem like they were leaking.
put it all back together. Looks like a small leak from idling can't really see where from but seems like the crank seal again. Quick drive down the street and oil everywhere again all up on the oil pan and over timing components.
when it blee the first time there was oil everywhere underneath too. My cats look pretty wet also.
Any help or directive what to look for or at as if I do this job again and it fails I'm going to lose my shot haha.
Hello
The spider hose system was pulled out and it looked like it had been replaced recently. Little oil buildup on hose that pulls straight from the block. Also the 2.0fsi coilpack conversion was all done at the same time.
I originally though this whole problem started from crankcase pressure but I'm not too sure anymore. I am going to pull the fron off tomorrow and see what is really going on.
any personal experiences? I've heard horror stories of the crank seal leaking 3x after being replaced.
Robson0172
01-26-2009 12:52 PM
Beaverific
11-03-2007 05:56 PM
MikekiM@PureMS
31
03-10-2007 12:15 AM
MikekiM@PureMS
12-08-2006 02:52 PM
jroczniak
10-27-2005 06:50 PM
