345 g/s for AWE RSK04 kit? From what i've read that isn't normal?
<center><img src="http://www.fastfour.net/logs/block003.jpg"></center><p>
damn thats ugly. T/C?
And at 345 aren't you running out of MAF signal overhead?
i think that is a shift in gears.... lol
I would guess that is rev limiter T/C before he shifted into next gear
You are correct. That was a first through 3rd gear run. Isn't 345 pretty high to read?
whoops, I'm used to seeing my slow-a$$ Stage 2 logs =\ Guess I should look at rpms next time, lol
VAG-COM seems almost useless for logging once you're that fast - though your sampling rate is slower than mine..hmmm
Your EVO intake is probably the root of that: Combined with that AWE MAF...
Those numbers look severely inflated. Your timing hints on a *rich* condition, log your O2's.
by far the highest ever posted - 280 normal - seen posted 315 running tcd +mbc @23psi ...
was this a stock kit with stock k04s?
Here is a log of my CF values, but i will get out and do some O2's tomorrow
<center><img src="http://www.fastfour.net/logs/cfs.jpg"></center><p>
That's actually damned good, duh.
It's because you're running rich. I'm so used to overrunning my MAF and running lean, lol.
I'm fairly certain the stepped AWE MAF when combined with that intake is the reason for it. Do you have any pictures of that setup? |
